Hey!
I’m building a diy board hopefully using a boosted mini deck, only one problem… After spending hours, I can’t find the width dimensions anywhere.
I am going to be printing a 3D enclosure so I need to know if the booster is wide enough for my needs.
If anyone has a boosted Mini x and can measure it for me I would appreciate it soooo much!
Thanks,
David.
74.9 cm x 27.9 cm
(29.5" x 11")
I assume the width is on the widest part.
11 inches is the trucks, that’s why it’s taken me so long to get nowhere
What else you could do is take the width of the baseplate hole pattern and lay it side by side to measure it out since thats universal.
I didn’t realise that, 42mm then?
Use that as a rough measuring method until someone shows up with a Mini X.
There might be a better way. There are certain apps, sites, programs that lets you draw lines and measure something from a picture if you get them a basevalue of the image/item itself.
