Got more straight cuts in for M1 and M1-AT
Ratios are 88/17 and 88/23
For M1 drive, the same 2.78 is available; 64/23.
Gone are the days of loose pinions.
Additionally, bonding surface area is now doubled.
POM plastic wheel gear adapter cuts weight + reduces wear.
For M1 drive, the formular popular 2.78 ratio is available; 64/23.
Pricing:
M1-AT drive wheel gear + pinion set: $89.99
POM Wheel Adapter Set: $22
Need a design for 3d printed gearboxes that assembe into a 6 axis robot arm. To use up the old helical gear sets that these may replace.
Any chance of getting the 2.2?
haven:
Any chance for ~4.6?
A 20t pinion would be a good middle ground at 4.4 ratio
haven
August 18, 2023, 9:31pm
#6
I’d love that, but not enough demand apparently
Still running the OG helicals with shaft collars, been holding up well for now. I may swap to the new 4.6 helical with the bigger contact area at some point, idk.
Straight cuts are the future. The demand will grow. I believe at least
haven
August 18, 2023, 9:34pm
#8
I’d agree… he offered to do a one-off but it would be like $140 for two pinions
That’s not so crazy for custom order though. I’ve spent more money on worse things before
haven
August 18, 2023, 11:34pm
#11
Yeah, honestly may just end up doing it lmao
I assume the straight wheel gears are universally compatible with the pinions? @Boardnamics
AlexB
August 19, 2023, 12:50am
#13
Just pulled the trigger on a set of BN 5.2:1 straight cut M1-AT’s for my upcoming off-road build. Can’t wait to reeee
Just double checking, $90 is for 2 pinions and 2 drive gears right?
Boardnamics:
64/23
I just counted my wheel gear on my bnm1and I swear it’s 50T
I’ll take a 88/17 with wheel adapters. Pm incoming
