Some seriously epic lathe skills and time
Yusssssss. So excited for the AT gear drives!
wait I thought the kegel adaptor would bolt onto those gears aswell?
No theyâre a totally different size all together. I can make a kegel adapter but I have a feeling 5 people would want it. The case is so big, that the clearance isnât very good on TB110s. The case outer diameter is roughly 100mmâŚso that leaves TB130 to be the only good option. Seeing as those hardly exist, itâs unlikely ill ever offer that.
What if there was 10mm more clearance than that?
I need to see an invoice from Labeda for 130s before I begin even drawing the adapter haha.
Is it possible to buy another/separate wheel adapter? i.e. run both TB110 & Bergmeisters?
The ratio would be a lot different on those two wheels. TB110 like a ratio around 2.8, TB130 around 3.2, Bergmeister more up there like 3.8.
So if you simply changed the wheels youâd either have extreme torque and low top speed or low torque and an unnecessarily high top speed that may not even be reachable.
Was the price for the AT setup ever discussed yet?
Only helical for the AT drive?
Making a run of gears is very expensive.
Adapters and gears will be available separately on the site tomorrow.
âŚI think this has been confirmed, but just wanted to double check - the SR adapter allows the GD to be rear (reverse) mounted, right?
Yes, since theyâre TKP trucks. Theyâre only able to be mounted with the motors in the back
Any plans for support for nicer wheels than bergmeisters?
Infinity hubs
Rockstar II
