someone on the forum can make that
Machine down my hanger. The dimensions are 18mm wide by 18.34mm tall
Iām actually trying to turn some hubs into dds and my plan was to file down a flipsky hanger to this shape, but the center hole itās too small for a 10mm shaft to go through. Do you think I can drill it big or will I fuck it up?
Edit: sorry for derailing
Nah dont. The hole will be off center and you end up with a wobbly thing. That sort of stuff needs to be put on a lathe. At least to my knowledge.
Why not go herringbone instead of helical?
All the advantages without any of the disadvantages
You should know thatās just not possible, right? Thereās never zero downsides.
Cost is the great driving factor for a lot of his design choices. Herringbone would raise cost a good bit, since the mfg is quite a bit more intensive with regards to time and tooling.
And his gears are too thin. Herringbone requires thicc gears to work well.
Anyone got this running with the 270 hangers?
Anyone got these at all?
I have them here but since the ratio is too steep for 130mm wheels, I could not use them on the latest build.
just put some together ya
would have been 270s but kevin forgot the order change while packing
uh oh @b264⦠looks like iāll be trading 110 for a set of tb130s @Tacesk8
If you like speed that will probably work fine but Iām a torque guy. 2.8 ratio on the 130s is a tad fast for me.
lol he said 45 is the goal, think itās ok.
prob should get him some split angles first :think
Meanwhile iām not sure 86km/hr will satisfy me on bergs⦠pointless as i donāt even know if these will ship this year at least but i like to dream i guess
Oh. Well at 12S the 2.8 ratio M1 drive on 130mm wheels is going to get you right up near 45. Probably 43mph (69km/h).
Nice
I prefer to build most of my boards for a top speed just over 30mph (48km/h). Like 31, 32, 33. (50, 52, 53).
Because I love the torque. Feel the POWAH and the RANGE
But I do have a board made for goinā fast
Thats what Iām talking about lol. It will take a little bit to get up to that speed, and to cruise at it comfortably. Current rolling at little over 30mph comfortably
Can the pinion size be reduced by 1 or 2 teeth? I remember there being alittle bit of adjustment.
