Boardnamics M1-AT Gear Drive 7:1 Reduction Interest
I have committed to them; will update the site to reflect the changes. Helical is still available upon request.
So i guess the question is lead time. What are we realistically looking at for a set of adapters?
I’m making them upon request. Once payment is made, it will take 1 week for me to cut them.
Fun fact: they’re made from leftover lacroix adapters
Just to catch up on this… do you have adapters for m1at on matrix 3? Or is that only possible for these higher ratio drives?
I am about to make a fixture so I can modify excess lacroix adapters in to MIII adapters. I will make them once someone orders them specifically as I don’t want to overproduce them.
The MIII adapters are not exclusive to these drives.
Well well this is interesting isn’t it
Ordering these today. Looks like there will be only 1 extra set made of these. After that, these are unobtanium. Pls reach out asap if you’re interested in these even if you don’t need them right now.
Will the 5.5 ratio gears you’re ordering fit in the existing M1-AT case (even if it takes a bit of dremeling)? If so, I’d be interested in potentially 4 sets of gears.
If not, I’m instead interested in the 5.2 straight cuts. Will they be kept in stock now?
How does the m3 adapter work now, when previously it wouldn’t work?
5.5 is possible on the original M1-AT with 16T pinions. You have to barely Dremel the slots to get that to fit since 88/16 is just outside of the shortest center distance possible.
5.20 straight cut for M1-AT is back in stock as of 1 week ago. No dremeling or anything required. Honestly recommend this route.
The supplier did a beautiful job with this gear batch, everything is spot on.
