It was cheap hardware, nothing wrong with bn baseplates, open all up and check it
I swapped all the Hardware its straight ahain
Sry for bothering
Sry for bothering
Goddamn, mine certainly aren’t in that bad of shape. I’ll have to take the baseplate off and see if mine are bent at all. I didn’t notice anything when swapping baseplates…
Is the hanger bent?
Geeze, what kind of risers are you using?
Jeez dude how much riser do you have that’s crazy long hardware
Haha yeah, i def had it to high…it was 2“ Hardware witha lot of shockpads and a big riser…i just did it higher because i was worried that the motors are biting the deck and the loopkey and because of the footstop and the antisink plate i mounted on top . Just got the whole deck lower now, hope there‘s enough clearance now
How the hell do you get these things to seat correctly? The wheel hub screws keep getting wedged before the wheel goes all the way down, I feel like drilling out the adapter is just going to make it rattle
I had to use a dremel grinder on my hub screws, and also drilled the adapter holes out just a smidge. And I still have issues getting them to seat properly sometimes when I rotate my wheels…
Damn, I guess 5/32" bit and a drill press?
I just did it by hand with the drill, but yeah I think that’s the size I used. Haven’t had any crazy rattling or anything personally.
The new wheel adapter system is a lot better
What’s changed?
The screws have sleeves and the plate is now POM plastic to make the assembly a little more forgiving
Ooh neat
My bits aren’t good enough to drill 304…this is an issue
Get cobalt bits and go slow
Aww damn, Kobalt bits aren’t good enough? Gonna hit the hardware store on the way home Tuesday
Trick to drilling stainless is slow speed and high pressure. Maybe try with what you’ve got and some lube
Sweet success, all wheels just need a firm push and they seat fully ![]()
Howdy, I’m mocking up some M1 drives to make sure I understand what I have to do once my motors do arrive and I’m a bit concerned that my setup won’t work as is.
The pinion gear seems like it’ll be too long for the case to actually close
