The only 1mm thick M10 washers you can get are aluminum crush washers
Washers, Aluminum, M10 Size, 10.2mm ID, 15.9mm OD, 0.8-1.2mm Thickness
This kit is overkill but look for bike axle spacers. spacers are not washers, spacers will be machined so that the faces are exactly (within tolerance) parallel. Washers are just stamped from sheet and the little wow they COULD introduce into the wheel stack up COULD kill your bearings by forcing them to rotate out of alignment, probably nbd but im tired of replacing my bearings lol. The rear bike axle is e often 10mm but not always so check.
Found em edit:
What is the diameter and thread pitch of the bolts, do you know?
https://www.boltdepot.com/Metric_socket_cap_Zinc_plated_class_12.9_alloy_steel.aspx
M4x0.7mm
Alright fellas. Anyone around here run 200x75 Phatty tires with their m1-AT?
My existing drive screw/spacer setup leaves about 1-2mm of space between the tire and the drive. Do you think this is rideable? I’m not sure how much the tires will flex under normal riding conditions.
Otherwise, best solution is probably just longer drive screws and a bigger spacer, right?
200x75
200x50 for comparison
Welp.
The left side of my drives decided to be cool like the right side.
Here is hoping I can get it cleaned up and going again.
The right side is still looking good.
Seems like the pinion loctite keeps failing on you.
Have you thought about going for straight cuts?
Yep. I had just messaged Kevin asking if they are available yet…
I’d be into giving the straight ones a try…
I have the 3.95 ratio and I like them a lot. Just be aware you need to dremel the mounting plate a little bit to get correct backlash. I do not know if this is an issue for the 3.0 or 5.5/whatever it is.
Pre-dremeling - not possible to set backlash close enough:
You’ll need the two dremel bits below:
That’s odd, I also have the 1:3.95 helical gears and there is more than enough travel in the slots, the motor can ‘rock’ back and forth in the slots with the teeth overmeshed
How’d you get that adapter? Is so pretty
Yeah mine started snapping at like 1200 miles
Yes
That’s the newest gen one.
Functionality any different?
Wow that might be the first busted tooth we’ve seen
I feel like I excell at breaking stuff.
Yeah it was a surprise for me. @poastoast can confirm.
I think Kevin is editing the mounting plate holes for future revisions so it isn’t an issue in future batches.
the straight cuts are indeed a hair smaller compared to the helicals
the helicals are like, 21:83? or something and the straights are 21:82 (3.905
