We have steel drives already ![]()
sorry
closed steel drives so i can also ride off-road
I’m not sure why you would want to off road on 3links/a raceboard setup
You’d destroy the whole deck and enclosure
not literal off road more on not great streets around me and occasionaly over a bit of dirt without having to worry about stuff getting in
also is it not ok for me to like a good looking board without some huge metal gears sticking out?
I still like the idea of the enclosed drives on the NKP’s, BUT; I have held the gears moe uses and I can tell you that anything that gets caught in there is getting destroyed, not the gears.
i’m not worried about the gears getting destroyed im worried about the gears jamming on me
I think if you consider that he lives in london, an incredibly people dense area, it makes sense. If you have a board that has an open geardrive I’d guess youre infinitely more likely to have police trouble (remember it is technically illegal here) than vs something where you cant see a big spikey gear and chain flailing round! That was literally the sole reason why I went DD/hubs initially vs a belt setup😂 fair @Halbj613?
yep that plus i live in london where half the roads are pebbles and stuff and also closed looks nicer
I mean its up to him, but I’m pretty sure I can break Mod1 gears on my board. For racing I see mod1.5 as the gold standard, the only way I’d think about using mod1 gears is on something like a cruiser or Emtb.
Evidence is Ive destroyed mod1.5 gears and I know people who have literally shredded the teeth off mod1.5 gears even.
Sorry for clogging your thread Kevin
Got you!! From that respect I can offer no insight, I meant purely from a covering the gear perspective
fair play on the teeth point.
Sorry Kevin
so i spoke to kevin about this and we are still discussing he claims they can handle the torque of a 6396 motor which is roughly 15nm
maybe mod 1.5 is the only way though
You need 300amps of current to produce 15Nm of torque in a 190KV motor ![]()
no idea
i used 3ds calculator and it came up with that number after gearing
remember thats torque on the wheel not torque on the motor
You are contradicting yourself in that case xD
sorry i am stupid you are correct
i should have originally said torque of a 6396 motor after gearing 3:1
Your never going to pull 15NM unless your racing (Pretty much)
I still dont 100% get why you are building another high powered board when you are just still touching the surface of what your current one can do
im not
this isnt for me now im just putting out an idea
but the gears have to survive then too
the idea is with this drive that you can use on a track or on the road
IF you are somehow pulling 15NM the gears will be fine because you would be pulling that on a nice surface
Just get channel trucks and huge wheels… trust me, nothing else works for london roads
time to try this @Halbj613
