They live there now Bro.
The alternative ain’t pretty…
grab a few super long M4 screws (either cap head or countersunk, it has to be flat), i usually use 50+mm ones, screw cap facing the ground, align those screw to the pins, grab towel or whatever for more grip, wrap around the wheel and force ur whole body weight on just the wheel, then pray it will come out
that’s how i regularly remove 3ds pulley from my TB110 / blue cag
That didn’t work for the China 'thane Boa cores when Rafael tried it. It just enlarges the pins and makes them stuck even more, like rivets.
It’s the knockoff fake china kegel core that is the problem, I think.
Think of this core as “kegel clones” in much the same way that “abec clone” cores are not 100% compatible.
sounds about right, that’s also one of the reason i can’t use the onsra 115mm wheels on anything
I think it’s the core at fault. The pins on my kegel pulleys run on the smaller side compared to other pulleys on the market. The fit shouldn’t require you stepping on the pulley to get it in. The genuine labeda wheels I tested all needed hand force only.
Yeah, I knew I fucked up as soon as I felt how much resistance there was. But then I promptly went for a long skate and forgot about the entire situation until many weeks later when I wanted to change things up.
Now that I am being more careful test fitting my pulleys before going full ham, I discovered that my TB100s that I always thought were impossibly tight actually have flipped cores. They fit perfectly on the wrong side. BC those wheels are center set I am planning to run them with the labels facing in.
Looking forward to trying out the 40t I ordered a while back.
