my DALY has 11 wires connecting to 2x 5s lipo, is this diagram correct?
Yes it’s correct, it’s always number of cells in serie +1
yes I meant the diagram for connecting the wires mb
Once wired, make sure to double-check with a multimeter that each wire on the bms harness is going up 3.x volts in order.
was fine when seventh wire from main positive went 0.00, but when I started from negative side it went back up in 3’s. is this just because the batteries aren’t in series yet?
Yes. Put the batteries in series and re check
