We’re going to announce MBS deals tomorrow, which will be active from Black Friday through Cyber Monday, but the black friday discount on normal MBS boards and components will be 15% which is the same as what you guys get with your forum discount anyway. So nothing too exciting there.
But… we are also going to announce some discounts on our MBS AGENT series which we rarely do. So that’s exciting for anyone interested in completes. If you have any friends interested in these please spread the word.
A big lever needs a big spindle.
Bearing placement behind the wheel load center increases hub leveraging on the spindle. A Narrow bearing spread also increases the wheels fulcrum over that spindle. A positive offset wheel also adds the this leverage on the spindle.
Match that with a standard size esk8 spindle size = an over levaged spindle.
The SRB big wheel front hub and drive hub uses the intended and proper bearing, bearing placement, bearing spread and spindle diameter that these Big wheels were intended to run on.
By having proper bearing placement (bearing under the wheels load center) spindle leverage is minimized in a turn.
The result is the hanger has the best possible control over wheel function both in a turn and over rough terrain.
