Anyone got any pics of the internals of a bioboard x4, I want to go for a similar build, 4 vescs, biggest battery pack I can make from moli cells, 270 or 320mm trucks, ain’t decided what motors to get yet, never built a board before so this is going to be a massive learning curve so I’ll be asking for loads of help, I’m still researching battery building, also not sure if I want to do a belt drive or gear drive, look forward to all the input and maybe some hate
If you want to do that then you don’t really need the internal pics of a BioBoard 4x4, it’s the batter in the middle with 2 outputs and a dual ESC on either end of the enclosure with a CAN cable connecting them
You will need to pick the deck > enclosure > ESCs > battery > wheels > trucks > motors > gearing in roughly that order if you want smooth sailing
I’ve already got the deck and enclosure on purchase, vescs maybe the trampa, I trust them, I’ll be building it slowly so cost won’t be an issue, main job is to get the battery right, I have a double enclosure like bioboard, just wanted to see the battery placement, unities on either end, trampa vescs maybe too big for my enclosure but I’ll find out when I get the bits.
I already own a g4x and trampa pro drive, just want a board for stable high speed riding, tb110’s is the route I want to go
I think this is only the case is you use a charge/discharge BMS they used. I have a 12s6p 40T dual unity with charge only BMS and there is plenty of room I think.
EDIT: this is the pack that was in there a lot of space taken up by the BMS
The bms is huge, I’d probably go for a smart charge discharge bms, been looking for trucks, fatboys are currently out of stock, do the bio boards use the fatboy base plates too?
