Sooo i was working on my loaded deck and decided to put bindings on top so i could try to jump up curbs and experience how a board with bindings rides.
But now this happened, stupid me placed a screw directly in my enclosure path.
Now do i remove my bindings and fill the holes, which will be ugly in my opinion or shall i cut out a piece of the enclosure, print a piece and seal it again which will compromise waterproofness and all the work i put in sanding and polishing this enclosure.
I think it would be best to countersink the holes on the bottom, and use countersunk screws… So reverse the bolt so that the nut will be on top of the board. Same way trampa does it btw!
@wandagoner and OP,
Pros
they are good for hops down curbs (not up), going fast over railroad tracks, aggressive starts in traffic.
Cons
They will hurt your toe side turn radius. The forums will never forget. You can still fall okay, but the perfect tuck and roll is less likely/harder.
I’m a proponent for half straps/hooks on street (freebord and yobis), MBs and trampa full straps on street is ballsey or stupid. Heel straps? GTFO.
