anyone know of a deck/enclosure that would be able to fit something like a 15s 10p-12p in an undermount enclosure of molicule 21700 cells?
That deck would have to be at least 48 inches long and have 10" tires and probably channel trucks at that scale.
Flux is 12S9P. With an esc up top you could do 14-15S.
Lacroix lonestar in 12S10P but they newest rev can likely fit even more. However you’re going to pay $$ to get you hands on one of at all possible. Also could fit higher S if you do esc up top.
Plan on putting vescs on top and only battery and bms on bottom
my plan was to use this deck here and make a custom fiberglas or carbon fiber enclosure to fit under deck only issue would be ground clearance.
Alan is working on a 12S8P double stack enclosure for the bro. Without the esc in the enclosure I would imagine 15/16S 8P is possible.
The bro is too narrow for that kind of battery unless you are going triple stack.
bottom enclosure + top mount case for sure will get u that 180 cell count u wanted…but its probably not what u want
On a Lonestar enclosure going DIY route you could probably fit a 18S11P or even 18S12P, maybe even more by doing a crazy battery layout
what do you mean top mount case? you mean batteries & BMs on bottom and Vescs on top deck?
do they even sell those decks/enclosures to the public?
would anyone know of the largest possible deck available to the public i plan on fabricating the undermount enclosure to fit everything myself so its more or less the deck i probably need running it with 8" wheels will most likely mount the vesc’s at both ends of the deck ontop.
Not my preference but i may even have to end up going for a more compact design and possibly going the lipo rout with a wiring harness?
Why do you need such a huge power station? What are you planning to do with this thing?
getting a bit bored of my current power house as i hit the top end limit. so want something i wont outgrow in 12 months i also dont want to lose the torque im used to. if i can get more torque top speed and range well thats just a bonus
Maybe get a snowboard and cut it down?
Only half joking…
Fair. Well that’s gonna be one helluva battery! Hope you don’t have to pick it up a bunch. Look forward to seeing such a build.
honestly, i dont see a need for such large battery, or maybe i just dont know what u using it for.
but @Skyart would know better
Power, speed, range want about 80-100km range high torque and about 80kmh top speed. Just don’t want to hit full throttle again. I want to experience what it’s like when I first got into esk8 all over again.
