Well if you do end up getting it, try out the default esc and whatnot, I quite like it and have no intentions of ever opening mine up to mod it like that
Theoretically it would be possible but you’d definitely want to make sure everything can fit before considering buying parts to mod it
I mean I’d have to take it off of my board to physically check, but I would assume that excludes the battery weight. The batteries weigh about 3lbs I think
Pretty much any deck except a deck with any kind of drop.
I’ve used up to 110mm wheels and I think the best experience so far is either 90mm urethane (most torquey) or 105 cloudwheels for a nice comfortable ride
110 torqueboards eat away a lot of acceleration and braking for people over like 150lbs. 120mm cloudwheels are a bit big unless you went 4wd
The hill climbing ability on 110’s is somehow still fine though
i like those cloudwheels, but my work route got way too many manhole which is slippery even with blue cag, i will see how those 105 rubber hold up first, heard they wear out very fast
No, I’m just giving my opinion here. There’s really not much of a reason to pick hubs over belts unless you just don’t want to change belts. Hub motor ride quality is worse, tends to be less powerful, and the PU sleeves won’t last anywhere near as long as full PU wheels would on a belt drive setup. I even gave a recommendation for a hub drive board in case that’s OP was dead set on getting. I don’t think that very much qualifies as “hating” on hubs.
