so what the title says i am looking for a cnc that can cut 10mm aluminium for motor mounts and delrin for a top mount enclosure, so far i have come across the workbee witch seems to be the best I can find at the its price point but i have doubts whether the stock machine can cut alu well, does anyone have experience with it?
other than that there is the shapeoko, but since i am in the uk it makes little sense over the workbee after import fees.
anyway if anyone has any recommendations that would be much appreciated, or if you are selling a cnc i am also interested - tank
Ugggg too bad ur in the UK, I have a great little router that want to sell. It’s do good, it’s just that my dad is buying an expensive one that I get to use, so I won’t need mine anymore.
Yeeesssss it’s a workbee, but with upgraded motors and a higher quality controller. It freaking mobs and does aluminum very well. I can churn out motor plates in 12 minutes using some nice fusion g-code.
So it has upgraded motors (I didn’t think they would make a difference, but it really does. It can cut a good bit better than my buddy’s with standard motors). Instead of the cheap controller, it has an open builds black box that allows you to use very basic software like easel, but also advanced software like fusion. Idk about shipping. Send me a PM with address and we can figure it out. Honestly a killer machine. Also if you grab a collet adapter, you can use the Chinese metric endmills which are dirt cheap and work very well. I mostly use 1/8 and 1/4 inch tooling, but a collet adapter or new collet would allow for the 4mm & 6mm chinese bits.
Oooo also it has the lead screw whip fix. Basically tensions it from the outside which eliminate leadscrew whip (very prominent on the older style)
