Hello
I’m trying to do something while I’m locked down.
I have an useless deck that I would like to turn into a short kicktail board.
Is there a way to bend an existing deck to add a kicktail?
If not, any way to add a kicktail?
Hello
only way I saw someone do this is by gluing/screwing a tail to the deck.
Bending the deck after is has fully cured will not be possible.
If you do attempt, soak the deck in warm water for a while before hand and bend in small increments in a vice, letting it dry between big steps.
To add to that, heat will also help soften the glue and make it easier.
Thanks gonna try hot water , we’ll see where it goes!
The best would be to have a mold to clamp the board to when it dries, to get its shape
Hot water, not just warm, perhaps not boiling but close should be good
Sure, I’ll clamp the hell out of it
Alternatively to a mold, you could clamp to a bench and hang weight off the end you want to bend.
@longhairedboy loves his wood conditioner on his veneers
but bending plies that have already been bonded together with wood glue? not so sure
Hmmmm… Louboard?
Heat and water? I don’t know man this is also the recipe to delaminate plywood. If it wasn’t plys laminated, steam or hot water bending would be a good choice but on plys, it is risky.
Oooh that’s a really good point to consider
Who made that killdozer like deck by cutting out another deck? Maybe try that?
I am not aware of any practical way of bending a premade deck… but I’ve added a kicktail to a flat deck before by glueing a block of wood to the tail of a deck and then grinding it down with an angle grinder fitted with a flap disk. It looked kind of like the NeoOne deck.
That’s what I did there too, time will tell if it holds up.
Looks really good. Fiberglass it and I bet it will work just fine.
Fiberglass is a good idea afterwards like tomiboi said. I guess it mainly depends on your weight, use (terrain and vibrations) and such before it would break. I would be worried about de-lamination and fatigue of the layers… but I also don’t make decks. If it’s just a kick tail, it should be just fine seeing as that’s mostly cosmetic.
Cut up everything and see if it works. and If it works, heroic Macgiver. If not, you scienced one for the team.
I have a feeling that any heat/steam/water enough to bend the laminated veneers would compromise the veneer layer bonds…
EDIT… like others have mentioned…
