Begode T4 Motherboard Repair/Diagnosis
Hey guys, just picked up a non-working Begode T4 from a coworker.
He accidentally turned it on with the motor not mounted and it spun up and messed up the motherboard/battery board.
I’m not trying to to spend $450 on a new controller. I’ve done my fair share of electronics repair, but am not familiar with diagnosing ESC’s. Could definitely use some input/guidance .
I’m fixing one now, waiting on a replacement charging board. A 40-amp surface mounted fuse burned out due to stator slip inside the wheel, both of which I already repaired. When I plug in the power to the controller to test it, it sparks! I’m hoping my controller is still good, do you know if there are schematics for these PCBs? I would like to know the pinouts for the charging ports, as well as the expected voltage going from the charge board to the controller board. Maybe we can share some info to get these T4s running again.
