Hi everyone,
Has anyone used Meepo board batteries for a DIY build?
Hi everyone,
I have not, but I have seen it done.
Keep in mind though, we are building battery-powered vehicles. Your battery is the most important part of your build. If you use a Meepo battery, then you are going to be limited to the performance of a Meepo.
Meepo battery are quite hard to disassemble if you wanna lay it flat, because it has a plastic structure holding the cells together
and 2p is not ideal, except if it’s for a small board and you can get the better ones (8.4 Ah i think), they sag a lot and cannot discharge a lot of amps at all
Thank you. I am on a hunt for a reasonable priced battery that I can trust and can replace easily if it fails in the future. Any suggestions of a good quality battery would be welcome.
PS I am based in the UK. So import/taxes can be an issue especially since Brexit.
Looking for either 10S2P or 10S3P or 10S4P or 12S2P
Keep in mine that if you buy too cheap, you’ll pay for the difference and more soon enough
What’s your build idea ? Wouldn’t it better to invest a bit more in a good battery ?
No.
A quality battery will last the entire life of the cells. Buy from a trusted UK builder like @Lee_Wright and you’ll get your money’s worth.
Meepo batteries are limited to 30A cont by the BMS, just FYI.
think you meant @Lee_Wright
Yes, fixed.
wish they sold these
