WARNING: This is so dumb and not safe. I did it just to say I made a tool from an ESC and Esk8 hub.
What? A rotating platform to grind, sand, and file on that can semi-center work.
Main components:
3 inch diameter, 3 jaw chuck. No back platel.
diy back plate with 3 hole bolt pattern to fit hub.
Inboard M1 hub, sans urethane.
chopped 8mm truck axle/hanger.
cheap, 2 axis cross slide vice.
Tupperware container for esc
flipsky 6.6 dual, broken, only one side works.
any battery, whatever.
Why? Idiotic procrastination project in lieu of drawing up CAD file for the 8 motor build. Also, we all like things that spin.
Where? TO THE LABORATORY!
How?
cut truck hanger on bandsaw
mount to cross slide
make back plate
mount chuck to hub
connect wires to esc
put esc in container
glue remote to foot pedal
connect battery and program.
Not pictured:
break taps in chuck
leave key in chuck while it spins up… twice. It hit me once.
get an end mill stuck in work and have it lift the work out of fixture, spin violently off center, recoil in horror, attempt to hit off button, miss, expose soft parts again to hit off switch.
Drilling Center bolt patterns, and maybe polishing / sanding.
Granted, center bolt patterns can be done by hand, and I don’t need a hub to do that.
I’ve used drills awkwardly held in clamps to revolve a truck axle I’m trying to cut/grind a notch in for a set screw. The chucks tend to leave bite marks. Drill presses rotate too fast. Manual drill plastic housings wobble out of fixture.
You can totally buy this for maybe 200$, but like, you can totally buy and electric skateboard…
I love repurposing projects like this, even though there are plenty of other solutions to achieve the desired outcome.
I know I could buy a 35$ a shaft and a propeller to put on my old brushed 9.6v craftsman drill that has 8’ of 12 awg, and has been fed 12vdc nominal, for near two decades now, and push the kayak around.
But,
Repurposing my small cheap hub motors, when their urethane is totally gone, their 7s ESCs and married remotes, and their 7s batteries to spin a prop, and broaden the areas which Fiona and I can reasonably explore on the kayak, is something i hope to have the time, and gumption, and skill, to pursue.
Even though I could just buy a cheap trolling motor, or a thruster.
