Teach Me Masters!
I am curious what kinds of drivetrain swaps I could probably do on my Ranger X3?
Would I be able to find a belt drive system that could work with the current esc or should i just build a second board already?
you’re gonna have to build a second board. That esc will only work with those motors.
I started to feel dumb as I posted it, kind of realized it after i posted lol.
Not an issue obviously, next time someone has a question like this (and has the mental resolve required to use the search button) they’ll have an answer available.
I see this all the time on FB too. Good to have info available like this
Or swap the esc alongside the Drivetrain
is it possible to reuse/cycle grip tape if I remove it carefully ?
use a hair dryer, and probably
True, thanks guys.
Using a hair dryer to remove only part of it at a time works best. Just lift it up enough to access any bolts and also use heat to get it back in place. Do not force it down or flat with a hand.
@DeckerBoards Are you interested in selling your ranger esc + Hub motors. If yes pm me please!
Not right now. I’m gonna probably hold onto whatever Esk8 parts I come across venturing into DIY.
@DeckerBoards Where I you from? If you are near Quebec Canada and want to try my DIY mountain board just let me know.
