Merry Christmas!
Been meaning to post my build here. After riding my Backfire G3 Plus for about a year, I decided I really enjoyed the deck/trucks but I wanted more. Converting it into a Zealot wasn’t going to be enough for me, so I decided to charge down the path of building a board using this deck. Below are the specs:
Battery: 12s3p Samsung 40T w/ smart BMS built by @jack.luis - Jackson is a great dude and made this pack to fit my enclosure. One reason I went with 40T besides the power is being able to take the 12s2p pack from my G3 Plus and run it as a range booster for this board if needed.
Motors: Torqueboards 6355 190 KV- originally I thought I would be running my original Caliber II 184mm hangars. With those, 6355 was the max I could fit. Now I find myself wanting more torque, but I’m debating keeping the 220mm hangars or making Boardnamics 184mm work.
Drive: Boardnamics M1 Gear Drive - mine is one of the early boards running this all steel straight cut set. Everything from Boardnamics is very precision-made and so far these have been a blast. For my first DIY, cutting my motorshafts was quite the fun head-first dive.
ESC: Lacroix Stormcore 60D - originally bought a Unity with a blown anti-spark. Had a keyloop made for it, but when we plugged everything in we got a huge spark from the ESC and it was friend. $200 down the drain…figured I would just get a Stormcore and have something with a warranty that could last me through several builds.
Deck: Backfire G3 Plus carbon fiber deck - choosing to stick with this deck has posed it’s fair share of challenges, especially fitting an enclosure that wasn’t designed for this deck. In the future I would probably work with deck/enclosure sets designed for each other or just got full on custom enclosure.
Trucks: Boardnamics 220mm hangars on Caliber II baseplates - considering dropping down to 184mm, but it is tight with the TB110s to avoid wheel bite.
Wheels: Torqueboards 110mm Artic Blue 72a - I’m a basic bitch that loves these wheels. They were one of the first things I purchased for this build.
Remote: Hoyt St. Puck - Custom Blue - won this in the DCESK8 Scavenger Hunt. Nearly matches my TB110s. Got a softer .45 spring for it and now it’s perfect.
Enclosure: Boundmotor - the overall shape of this enclosure looks like it was made for the G3 Plus deck, but there are flares in the corners and center designed for its original deck that made fitment a bitch. After lots of experimenting with layers of yoga mat I am now pleased.
Bushings: Original Backfire G3 Plus - need harder bushings if I stick with 220mm hangars. Possibly all barrels in the rear.
Running this at 60amps currently. Loving the setup, but starting to want more torque.
