Axial Flux Motors? Anyone researching ?
So, this looks interesting. https://spectrum.ieee.org/axial-flux
Why not replace BLDC on a e-skateboard with these ? Seems that they would be more reliable, but maybe the diameter required is too large ?
Motors that emit carbon? We’ve gone full circle back to brushes again.
/s
i am looking into it. seems like they would perfect and crazy powerful. would probaly only require a single center mounted motor as well! Just need to find the right company/size and a single shaft extending out to each wheel…or make them hub motors. Id say it would revolutionize the industry.
Would inrunner motors with a big gear ratio get most of the efficiency there is to get while being able to reach high power?
on second thought – this motor design is for AC, not DC as supplied by batteries so this would require a lot of things to change.
BLDC motors are AC despite having “DC” letters in the name. We use ESCs or electronic speed controllers, to generate the three-phase AC needed from a DC battery.
Smallest standard frame size currently is huge, this seems interesting but it doesn’t seem mature enough yet or the market for smaller frame sizes just isn’t there yet.
https://goinfinitum.com/products/aircore/
The .75 to 3.75kw motor frame is 62lbs, obviously an industrial application and not a ev or pev focused design. Interesting but probably not going to be anything available for a decade or so. Maybe there is a different manufacturer than the one i found but this is the only referenced manufacturer in the articles i could google.
Huh, yes… that’s right ..
