No down payments unless its a group buy, All Payments are handled through paypal . No payments are handled through friends and family!
If there is a specific print you need just supply the STL file and i can have it printed for you, If you also require other parts for example screws or electronics or would like something built for you i can also provide that service.
Print Bed Dimensions
Length: 280mm
Width: 280mm
Height: 380mm
Available Materials
PLA+
PETG
TPU
These are some of the finished prints i have done, Debured, putty, sand and Air brushed with a glossy non yellowing protective finish.
These parts are for the Firefly Nano Feather remote, these are the outer shells.
All parts painted with 2-3 coats and a gloss finish.
time it takes to print, type of material used, difficulty of the print and how much cleanup there is for the part as this requires manual labour. if a print is prone to fail due to a bad design it would generally be more as it leads to wasted material but i do try my best to avoid this. but i generally try to slice it for best strength and users requirements.
FireFly Nano remote is $25 for PETG White
Firefly Nano remote $20 PLA+ Black or White (Will have to check stock on White fillament)
These are debured and sanded to a smooth finish or can be left with the 3D printed feel/look if you please. Unfortunatly i can no longer spray these as i have moved into an apartment. and i do not have my spray booth with me.
Alrighty seems this post is getting a little rusty. I have now moved back to melbourne where i origionally started this short lived journey before moving insterstate and living a busy apartment life. Now that i am back i plan on getting back into commission prints and have some juicy printers on the way by the end of the week. i have since gotten rid of the FDM printers and have replaced them with a couple resin printers to help keep the smaller detail in check. Should have a few test prints coming along possibly this weekend or the next!
