Arythmia 4WD - Boundmotor Octopus
7 posts were merged into an existing topic: Dreamonseed AF-
thanks fam
Shits gotta happen here…
The Deck. I’m going to strip it back to timber, shave it on the rails and build a 10mm wheelbase extension to both ends. The wheelbite on 200mm is just awful. In fact most things about this deck suck but im determined to make it better.
Hardware: M1 GD x 4 upgrade is happening. I never built this as a mountainboard and i dont expect it to do that… but FMD if it cant cross some freshly cut grass without filling up the pulleys with shit… somethings gotta change.
Electronics. Mostly all the things i did. Jumpers gotta be done differently and more simply. Lights reinstalled and wiring fixed. Loop key was a cockup by installing on the angle of the enclosure, that means it sticks out under the enclose and is at risk of being ripped out. Stupid…
Its essentially a complete rebuild into a different board.
The settings its currently running on are these.
86.5kg unloaded rider weight. (190lb)
Rear:
Motor max: 100A
Motor Max Brake: -30a
Batt Max: 55a
Batt Max Regen: -35A
Front:
Motor max: 60A
Batt Max: 45a
Batt Max Regen: -65A.
12s6p P42a
205kv 20/78
Curious to others 4WD settings
Its very lively, and i love it despite all the negatives
