1 thing i hate about flipsky is their lack of a detailed explanation of their products
Simplified version:
Customer: “hey what are you using for so and so in your product?”
Flipsky: “”
(This was an actual conversation i had btw. Had an esc that burnt out and i asked why it may have happened and what i can replace to fix it and they had no clue)
I’ve only used Zealous on plastic cores, they’re a pain to get out. Does anyone know if these pullers work on them? Doesn’t look like there’s enough room for it to lock in
I just use a wooden stick and smack the bearings out💀 thats gunna anger a lot of people here but HEY i do it on the outter metal so im not really harming anything
for esk8… zealous all the way. I used bones reds for a long time. they wear out faster in my opinion and spend more time feeling gritty during their usable lifespan. I’ve disintegrated several sets of reds and have yet to do that with zealous bearings. zealous have just been way better for me.
“reds get you started, zealous keep you going”
At least that’s what the local skaters say, and having skated for just under 10 years I’m inclined to agree.
I definitely haven’t been in the sport anywhere near as long, but I haven’t been able to justify buying anything other than Zealous for 22mm bore wheels the whole time
I saw nice technical comparison of sk8 bearing and Reds was not a winner. If Iam remember correctly they was somewhere in the middle of chart. Reds have very good marketing. For clasic Skate You will newer see the difference. But on Eskate You will. I must search again this video. Anyway also guys in longboard shop recomended me for eskate Zealoas and they are best bearings ever had. Realy recommend
awww thanks, but no need. In 30 years of skating I’ve never needed anything other than a screwdriver or truck axle to remove bearings. Just wondering if they would work on Zealous sine the “spacer” doesn’t move out of the way
I’ve found a lower abec rating generally performs really well on esk8 hubs. High Abec rating generally has better freeroll and speed but I also find them more fragile. Abec 1 doesn’t freeroll as good but they last a lot longer for me personally then other Abec ratings I’ve tried…also don’t get ceramics lol not sure if this is anyone else’s experience but mine were ruined after the first ride… It’s very rare that I have to change my bearings, this is part of the reason I now stock them. NSK 608DU C3…shameless plug incoming
