Can you drive 2 vescs via canbus from the android vesc tool? What’s the correct setup for this?
I’m waiting for the last few bits, including the remote, and in the app i can only control 1 side at a time
Has anybody tried a split-truck length setup? Say for example a 275 hanger in the rear and a 240-260 up front. The idea is to improve carveability but would this affect stability in any negative way?
What are the practical benefits and drawbacks to using lipos vs li-ions, and vice versa? Ex. voltage sag, more charge cycles, durability, safety, etc.
For background, I’ve been considering LiPo for a build because it seems cheaper (2100Ah for ~$400), more plug-and-play, and I already have compatible chargers and voltage alarms, but I have no idea if they last as long or are more sensitive to vibrations or whatnot. Li-Ion seems safer, but is much more expensive because I can’t build my own packs.
I have been reading a lot before posting this, but the amount of info is overwhelming.
I’m building a 12s3p molicel p42a battery pack using NESE modules. I want to connect each modules using ring connector and 12awg cable. Looking around i can only find ring connectors rated for 80A. Each cell is rated 45A continuous discharge, even my plan is to only pull 30/35 A for better battery life, 30x3 = 90 A. Would this connectors stand it? should I aim for the 135 max A just in case? is 12awg cable good enough?
I’m thinking about this bms for charging only.
I will order it for 12s, 20A.
My deck is a zenith rocket v1, and im kind of tight for the components, that is the reason for that bms.
What do you think about It?
And my last question, a 15 A fuse between the bms and charging port is to high?
Much higher energy density and specific energy. A worst-case 1-liter cube of Samsung INR18650-30Q cells (square packing, none of that fancy hexagon rubbish) has 512Wh in it. A solid 1L cube of Turnigy Nanotech 65C Lipos has about 266Wh for comparison.
Generally considered to be safer, E.G. les likely to become fireballs when abused.
Datasheets are available with real numbers.
Have their own metal shell for puncture resistance and the like
Can have much longer cycle life
Cons
Lower power density - Takes more cells to get the same number of watts.
Depends on the type of wire. Multistrand, solid core, etc. Typically, you’re going to be using multistrand though. Also depends on length.
12AWG cable is rated for 40A-60A and at shorter lengths, can be higher for brief periods of time. You should be fine with 12AWG. Most XT60s are terminated with 12AWG. Most XT90s are terminated with 10AWG. Should give you an idea of which cable you need.
What motors are you running pulling 90A continuous? That’s pretty intense AT board territory
Fusing rule of thumb is twice the charging current
Thanks! I always thought LiPos had higher energy density, especially since it’s solid vs the airgaps you get from having cylindrical cells in a rectangle. Li-Ion does seem to make more sense for esk8s. They do seem pretty heavy though compared to a comparable LiPo build - in my calculations, a 12S2P 2100Wh LiPo would be 6.6kg, while a 12S12P 40T 21700 that’s also 2100Wh build would be nearly 11kg. I think I’m leaning towards LiPos right now, mostly due to cost and lack of any way to build packs.
