do you know the max width i can use on a 21700 battery? a bit smaller than the positive terminal
What’s the best way to adhere everything to a deck\ enclosure? Do you prefer Velcro or tape? Links are appreciated
screws/bolts
I think he means battery/vesc(s)/receiver. For which 3M Dual lock is kind of amazing.
possibly fixed the issue. I changed the Motor pulley again to a new one and currently test it out, so far no weird sounds from it.
How do i know when my motors switch from sensored to sensorless?
At roughly 35km/h i feel a small jolt like shifting gears with forward momentum. I want to know if the jolt is caused by switching to sensorless or if it’s the 2 shunt design of the vesc 4.12
how do i know if i reached 200/2500erpm
2000ERPM is around 4kmh, the transition is almost unnoticeable. Jolt is throttle interpolation but you can make it smoother changing the throttle curves.
thats what i have set
the acceleration is smooth from 0-100 except that one point where its like i activated a tiny turbo. If i passed that spot its smooth again.
edit : it happens at around 55-60% duty cycle
I normally mess with the graph with the exponential line on the PC VESC tool, no idea how you’d change that on metr.
My throttle curve looks like this. (found a random graph on google that looks similar) Mine isn’t as aggressive as the picture. And yes the orientation is correct, i flipped the image on purpose so it looks like mine
My trick is to taper the last 75% so that it’s a very gradual increase and so when the 2 shunt limitation kicks in it’s a little bit less aggressive of a change. But you already have that so I don’t know why its messing with you.
When I’m back home from my ride i can show you my actual stuff. Maybe that helps
Can’t hurt
What’s the exact size allen key needed for motor shaft grub screws? I got the smallest in metric which i think is 0.8 that’s too small, and smallest imperial, too big -.-
it can differ from pulley to pulley so you have to try a few.
i use 2.5mm and 3mm hex keys.
2.5mm for the integrated ones and 3mm for the external ones.
2.5 top
3 bottom
looks like 1.5 or 2
do you have calipers?
Non- digital calipers are cheap
You’re looking for 2mm
