Ah, I thought that was more to do with value of parts than power Iām just goofin
I mean, the pricetag is pretty similar all told.
Ahhhh Iād say gaming stuff is wayyy higher for top of the line stuff. I mean, whatās a top of the line ESC run? Under $1kā¦ A RTX titan graphics card puts a $2500 hole in your pocket and youāve only got 1 part out of 10 to complete itā¦ Then an i9 puts another 1k down, start tacking on water cooling and before you know it, youāre 10k in and you havenāt even bought any games yet.
Iād rather do hookers and blowā¦ thankyouverymuch
So there used to be an outstanding guide on threading inserts for enclosures and I canāt find it for the life of me now! Can anyone find me the link? Promise I looked, maybe Iām just unresouceful
this one?
I put in āinsertsā in the search function on the main pageā¦ second entry down then I stoppedā¦
I dunno what it isā¦ maybe left over flux from when they were solderedā¦ clean them up with iso alcohol and reheat shrink if the soldering looks good
Spring trucks. What angle gets the most carving? 30, 35, 45? From what Iāve gathered, 35 is best. Just wanna verify
Question: does a heatsink plate have to be mounted through the enclosure or is it still useful within the enclosure
Still useful since it draws heat and radiates it out/away.
Thankyou !! Whatās the best way to mount it? Fins down or upwards towards the vesc ?
Fins out. You want as much contact area as possible with the heat source.
and maybe you want to use heat conductive paste for better results!
Appreciate this help. I got a hummie deck so Iām mounting to the board since it has a cutout. Since Iām doing I have to find a way to stick the fins to the deck ha
Mini remote all day long. The travel length on the trigger is very long and allows very precise control.
The TB6380
In all seriousness though as @Niklas said, ābetterā is a vague word. Tell us more about what you want.
Are you using two motors or one? Dual 6355 is underrated imho. For a single, I would use bigger than a 6374. Dual 6374 is almost overkill in a lot of scenarios.
It really all depends. On a lot of thingsā¦ Tell us what you want.
Thanks @kook, but thatās not the one. It was a step-by-step guide, from drilling the holes, to putting in the inserts. I remember the main post had an EVO Falcon he was using as his demo. He detailed the hardware, which was M4 screws, and anodized washers and o rings and everything. Canāt find it anymoreāwas it on the other forum?
I wonder if with 135 Lbs, 1800W of power with a 15T/36T ratio and 170KV is fine. Would you also recommend me to go 6380 instead of 6374? I canāt even max out on the motor because my VESCs bottlenecks at 50A whereas my motor would take up to 120A
There are some 3d printed mods for this remote that make it even better.
