@ducktaperules do you use any sort of consistent PSI setup? Any pump with a good accurate gauge?
@mmaner , even if I get a bike, retard^2 still dictates Iām going to obsess over my tire pressure. Do you have any special preferred pumps up your sleeve?
I have connected a buck converter to my lipos (10s1p) to power my leds. It drained two of five lipos to unrecoverable voltage IMO (below 2V) (Yeah, smart me). Since then I have replaced the faulty lipos with new ones and sorted the batery draining issue. The problem is that the new lipos came āstorage chargedā to 3,8V. The old ones in the pack were 3.6, 3.2 etc. When I fully charge the pack the BMS seem to balance them, but this process is super slow (about 0.3V of balancing per 24H). Is there a faster way to do this??
Nah I just wing it usually. Pump them up till their about right +/- 5psi (accuracy of my pump) then forget about it and go have fun riding. If they feel low I put some more in.
Iād been doing my street slicks by feel just fine - however once I started using hard rubber knobbies, I couldnāt feel a difference between a good bit of air. Main reason Iām giving this much effort. Iāve also noticed a decent difference in my ability to glide over craggly hump-laden brick roads at high speed with some slightly differing pressures across all slicks. Probably not a thing a lot of people find the need to care about, itās just bothered me a bit.
Not exactly. There are 2170/20700 size cells that match the 30Q or VTC6 in both power density and energy density - Not too surprising, itās the same chemicals, just stuffed in a different can. It just happens that the one you picked, the Sanyo 20700B, is not one of those. The Sanyo cell is actually moreenergy dense than the 30Q or VTC6. The issue is, the tradeoff between energy density and power density - Itās less power dense than the 18650s I mentioned.
Ummm wtf did I do to this motor. The motor itself spins while the pulley on the motor shaft stays in place⦠when I put the cover on with the gear for the wheel the motor spins by itself.
Uhh anyone what I fucked up here. Vid below.
