yeah yeah it could slip off the shaft, but your looking too much into an oversight in my message. Sure, let it have a build in set screw, but you canāt deny that the D shape would help when these set screws come loose as they frequently do.
Do I care that it is hard for them to machine?
No. I just need ta find one.
Flipsky and evolve sells D pulleys in steel but only 15T
Boardbumpers also sells a 12T and 19T in the D profile in steel. Some 20T aluminium floating around on ebay
Oooh so closeā¦! Iām running an 18/40 setup on 190kv, I got plenty of heat already, not looking to go much higher. Thanks tho, didnāt even know those guys existed
just different belt tension ?! Or should I check VescTool for inconsistancies? [dual superfoc canbus]
Have you tried taking the belts off and hand spinning the wheels to see if theyāre equal? Itāll help narrow down the issue a bit.
Thanks ā¦ I will try that
While the belts are off, run the same test in the videos and see if the motor cans slow down at the same speed too. Good luck.
That one wheel is fairly out of round as well.
Yes it shakes
For Caliber profile, what gear drives are available? Seems like multiple gear drives fit other truck profiles instead
ask 3DServisas
I should add that Iām looking for gear drives suited for AT wheels. Terrain here in Dallas is super bad, AT is almost a requirement
Belts are extra nice with At wheels since there is more teeth to grip.
wouldnāt the silence + cost be nice.
I understand if youād want to go off-road then thatās different
Yeah Iāve ran belts before and liked them, I just wanted to see what the hype about gear drives is about
At this point, Iāve done just about everything except for gears (belts, hub, dd, flintstone) haha
Can I ask you do AT wheels fit on calibers?
like say the evolve ones?
If so I assume you just need a longer mount so the wheel doesnāt rub vs the motor pulley right?
Same desperate to get a pair of gears just to try them out but can never justify paying full price
I use cheap aliexpress 6X2 wheels. As is, the wheels will not fit on standard caliber trucks. The hubs are too thick and I wasnāt able to thread on the lock nut after putting on the wheels on the trucks
Iām currently running DDs using AT. Obviously no issues here with clearances
I do have a pair of caliber profile trucks with extended axel coming in so I can let you know if itāll work or not. My guess is it should be fine with long enough of a mount
Anybody know if this is normal for bamboo decks? Iāve seen it on other bamboo decks before but Iām a bit worried, looks to be cosmetic though
I want to put this out there that part of evolve rubbishing exway is Jeff is working on a low cost evolve. The stoke isnt selling well in b&m retail markets and he really wants a low cost alternative. I have heard rumour to the effect. Jeff in China may know moreā¦
Ah shit. Here we go again.
