It depends largely on the cell and specific chemistry some have lower discharge voltage but there is always a âcliffâ in the discharge graphs after you get beyond some voltage it pretty quickly goes to 0 and if you hit the edge of the cliff the cells sustain some damage and you lose cycles. Setting higher cut offs makes sure under load you donât pull the cells down to the edge of the discharge cliff.
Iâve set my vesc voltage cutoff to 42-40v.
Just came back from a ride and plugged one of the batteries in my charger which says its at 7% with a voltage of 21.3x volt or something.
But thats what i donât get. if discharge about 4v from 100-7%. How can there be 3v left but with only 7%?
Look at discharge graphs the lines will be colored based on how high the discharge rate is the area under the curve is the charge used over time the area under the section beyond the âcliffâ is very small there is little usable energy even though the voltage is still pretty high the Ah left in the cell is small.
Because as batteries discharge (especially lipos) they contain less energy, for example 70% of your riding will be in 4.2v - 3.7v even though you still have .3-.7v left it contains only 30% of your remaining energy and is better off not worth discharging to allow your batteries a higher cycle life.
So its pretty much crippled energy. As if you run a marathon full of euphoria but you are unable to run the last 30% because your legs canât do it anymore. And if you try you might hurt your legs even more.
Yah the charger also just has some table that says x voltage is y percentage and does some mapping for values between so the percentage is based on ranges preset into the device. Realistically you can use an artificial load and a bench power supply to stress test cells to see where they really break but can usually take MFG word on the limits and maybe add some padding since everyone likes to fluff their numbers.
If youâd like a solution that just works, sure why not
pic from The Definitive Guide to Metr App / Metr Pro
software at Garmin: VIRB Edit for Windows Updates & Downloads
Does this force me to only use Garmin action cameras?
No but the tools sucks. Havenât got a precise result yet, its always 1-2 seconds ahead (the data)
You can use any camera footage
no! you can use any source of video! @rpasichnyk & @hexakopter took the time and effort to automate exporting the data collected by Metr into the format that can be easily read by that Garmin app
Welp, I could install the Garmin app with Wine on Linux, but canât launch it. Will need to choose a different solution.
I hope they are ready for their pack to be worn out after 50 or less cycles
have you used winetricks to install a win32 .net framework
Having Windows in a virtual machine often works. Get VirtualBox and a copy of Windows
There are test virtual machines provided from MS for different variants of IE testing but think you can probably install some stuff and use it at least on a temporary basis if wine doesnât work out or is more trouble than itâs worth.
GPU passthrough for editing programs that use it and other things can get hairy in VB though.
garmin virb edit relies on ffmpeg to do all the heavy lifting, no gpu passthrough needed @wafflejock . sucks that the ui is .net based but if you can get .net working under wine you should be good to go. you can also try running the macos version on darling @rusins
I got that same noise only while accelerating and carving simultaneously. I first thought it was idler bearings now I think its coming from the motorâŚMaytech 6374 sealed. I got new idlers and I bearings gonna swap them out and see if that gets it.
Is there an inherit limit to turn degree for trucks? In other words, can I increase the angle of my trucks (ignoring issues like bolts not being properly seaeted) until 90 degress and get an increasing range of turn?
If yes, it seems like you would be able to make poor turning trucks more maneuverable at the cost of maybe performance such as âcenteringâ or âsnap backâ.
I ask because I recently bought a cheapie board with no name trucks and noticed that there were wedges. The board turns horrible but I wonder if the company added trucks to attempt to partially increase turn?
kingpin angle is your answer⌠the more angle⌠to a degree, the more turny⌠such is the aim of wedging and adj baseplates⌠it effects truck mobility and turny-turny more than bushings⌠in some aspectsâŚ
Can you use vesc tool on Android connected via otg?
