Yeah, all the ports on a vesc (at least the vescs Iâve used) are PH 2.0mm.
Heat. All those lovely amps are heat. simply put.
My favorit thread
I have 10s3p 30Q pack 9Ah
i got a 42v 2a Charger how long to charge it from 0 - 100%
9ah / 2a = 4.5 so 4.5 hours or how do u calculate?
Thatâs about right.
It tapers a little at the end, so maybe a little more time.
Batteries wear out, so maybe a little less time.
But the biggest difference is that I rarely completely discharge a battery so itâs usually a lot less than that.
Yeah iâm avoiding that. Tack 4 the quick help Btw.
I fully subscribe to @b264âs all boards fully charged whenever possible philosophy. The few times I didnât use this approach I regretted it. I donât care if itâs the wrong plan for longevity.
I only leave a board uncharged if itâs broken. Then I still always regret it because when I fix it, I have to wait for it to charge. But it seems silly to me to charge it, if itâs broken. The batteries would prefer not to be fully charged, and I know itâs not going to be riddenâŚso I leave it in the 50%-75% full zone
How does one calculate peak discharge of their packs? I made a 10s6p out of molicel p26aâs. They are rated for 35a continuous but I canât find the info for peak discharge. Anyone know what settings I should type in my esc?
For info: esc is dual flipsky6.6 and motors are 190kv 6354 with a 15/44t on 125gummies
The P26a only have a discharge of around 25 a rather then 35 a
Not according to the new data sheet I just saw from molicel
Data sheets donât mean much. You have to try to find discharge graphs made by someone who is not Molicell.
Lol I know the sheet i have saved in my phone says 25a. No clue why all of a sudden itâs possible to be 35a but in either case I donât want to push the esc that far and doubt my motors could take it
Youâre both right. Mooch says 25a. Doesnât change my trouble though
Also another noobie question. My pack is with a bypassed bms. Pack reads at 41.9v but bms reads at 41.4v ⌠normal?
I never run my cells above their max. continuous rating. Too much change of damaging them and/or adversely affecting their cycle life. Plus you have 6p, 25A/cell should be plenty of juice.
Why are 6s chargers at 25.2v? shouldnât it be around 22.2v? wouldnât the charging light be forever on red and never turn to green?
Full charge of a lithium ion cell is 4.2v
Would JB weld Clear be good enough for battle hardening a motor?
Not sure about the clear. The time I tried to use JB Weld 8266-S original forumula to harden a motor, it was a massive disaster.
I found out it actually has steel in itâŚ
The clear doesnât seem to have any additives like the original formula does.
I might give it a try.
