Yeah thats a option but as i wanna use evolve trucks i was looking to do something different for the deck. May end up just getting a BGTR and moding it over time
The BGTR is honestly pretty dope if you’re not looking for a speed machine. Nothing really wrong with it other than just a little pricey.
It’s the 41.3 x 63.5mm that can be found on all of our trucks.
Good to know! Thanks.
This thread is for furniture. Is not good for use for skateboard.
@eBoosted makes some nice fiberglass ones
10S4P: https://www.eboardsperu.com/product/loaded-vanguard-enclosure-set-10s4p/
12S4P: https://www.eboardsperu.com/product/loaded-vanguard-enclosure-set-12s4p/
Which do you think would be best for typical skateboard decks?
^^ appears roughly the same to what I use and was shown in the post and says is for soft wood, other options with T-nut style but I prefer more thread in contact with the wood. The motors we use also typically weren’t designed for esk8 nor most of the decks but we are repurposing things. Anyhow any better options from mcmaster or somewhere else?
Also for what it’s worth I’ve been using these kinds of inserts for a couple of years and no major issues I’ve seen… holds up like a lay-z-boy
yep pretty weird. one way to think about it is when you run current through a coiled wire, you’re polarizing the vacuum, which stores up some energy in the form of a magnetic field. if you put some iron in the coil, you’re polarizing the d-orbitals in the 3rd electron shell of the iron-56 atoms as well, which has a much more pronounced energy storage / magnetization effect than polarization of the vacuum alone…
Interesting…
So basically this “storage” effect is what’s causing the current flow in the motor to remain more or less constant over the duty cycle of the esc…
I now understand why flyback diodes exist
Running detection and fixing settings, run it on the bench, and get this mess…it got up to speed, startEr skipping, then cut out (one side then the other), then then connection to the ESC dropped
Is this problematic? I feel the motor current shouldn’t go negative since I slowly ramped up the throttle and held it…
Temp stays under 40C, ERMP hits 40K and holds even though its capped at 50K
@ZachTetra were you in duty cycle control?
Nah, current smart reverse
It keeps cutting power when I bring it up to 40K ERPM
can we see the whole graph with legend
Gimme a minute
10s li-ion, focbox 1.6, flipsky 190kv 6384, 60/30 motor amps, 30/10 battery amps, FOC, sensored below 2500 erpm, 50k erpm limit, current smart reverse control, low power mode on nano (70% I think)
you specified a 50k erpm limit? that might be the cause
It never hits it though, it shouldn’t even be able to go that high
i think you’ll hit it at 38v with a 190kv motor and 14 stator teeth
