This post needs to be migrated here: The Difference Between Motors Commutation BLDC vs (FOC Trapeziodal / Sinosuidal) - General Discussion - Electric Skateboard Builders Forum | Learn How to Build your own E-board
Also, BLDC stands for BrushLess Direct Current and FOC stands for Field Oriented Control. I think what people usually call BLDC is actually PWM which stands for Pulse Width Modulation.
Someone please correct me if I’m wrong.
Hi
I need some advise
yesterday i changed the esc on my meepo classic … and yes of cause i switched the wires too the motors wrong
so now when its in reverse it goes forward
so my question is = is it okay too just let it be that way?
The brake still works
Just switch 2 of the phase wires around for each motor and it should go back the right way
Thanks for answer
yeeaaa… soo the problem is that i first discovered this fail after i super clued around the esc case,
so stupid.
so i really do not want to open it up again, if possible
Do you think it will cause a problem in ride ?
Nah i don’t think there will be any problem
do you get the same speed and torque in reverse as you do in forward?
Hi was wondering if I could use a flipsky vx2 remote (uart port required) but not use canbus so something like instead of split ppm we have split uart
Awesome !
yes i think it is the same but i will test that today
You can keep it that way (if both motors spinning in same direction) and just leave reverse direction set on the remote. Just make sure it doesn’t reset/revert when the board and remote are powered off and on.
Okay so i just did a test and got some pretty interesting results
Dont know if it a result of wrong wires or the fact i also changed the PU SLEEVES magnets ?
But i still got speed and its faster than before
Before, topspeed =40 kph
Now , topspeed = 47kph
either way im not complaining
maybe your new sleeves got a bigger diameter than before.
if you switched to 100mm now it could be.
Yeah no worries. I have a hub board that does this, I just leave it in reverse and put an F and R sticker on the remote just in case.
Thanks for answer
So both motors is spinning same way, and if i set it in forward it goes backwards.
it looks like i can revert it with no problem ? but dont know
Awesome !
the last thing i would like too do right now is to open op the esc after the superglue treatment
next years fix
the wheels is same size ? but maybe magnets got bigger
but the faster the better right
look- meepo offers 2 sizes of wheel sleeves within the magnets. 90mm and 100mm. the bigger the wheel diameter the higher your top speed.
I could bet you had the 90mm and now them 100mm!
Where did you get the readings from? Because this would not happen. Same motors, same esc, same battery=same speed.
went from 90 mm to 90 mm wheels no change in size 82517384_2558307704402289_1232286895304605696_n|666x500
30 min ago i did a speed test outside, with gps speedometer
I also think its strange
If you find it faster, all that matters.
