So before i had opened up the battery i emailed their team to ask for the battery and BMS specs. They replied with the follow specs (below picture) I read that and was like wtf, why would they put 60A when the BMS clearly states 40A. Let them know putting up incorrect information could possibly lead to injuries. smh⌠lesson learned.
The stainless inserts are much better⌠a lot more expensive but easier to achieve a good finish with a flush surface ready for a nice neoprene hatch seal.
If I was you I would not use those inserts. Donât even try installing them using an allen wrench. Instead, put a bolt in them (with a nut, found that easier) and install them that way.
When you want to be sure you donât ever have to break your board getting them out, get these:
Anyone here ever successfully parallel two escsâ to a single motor?
Whatâs the voltage? Those look like generic 12v or 24v cobs. Theyâll turn on when you feed em enough voltage but still recommend a constant current driver if you want any real life out of em.
No idea. I got them for free without any infos. I tried some small remote lipos but not 24v yet. I only have a massive 1.5kg 12Ah 6s lipo that i could try.
Slapping random voltages on without any info might just blow them instantly. But the only other option would be to use a CC-CV driver and progressively stepping up the voltage. If 12v doesnât do anything, then maybe 24v will. Or it could be even higher, They range possibly from 3v up to 50v.
Nice - So I had originally posted as I was having terrible trouble getting them out (2 broke inside the deckâŚ) and I am installing my gear on a new deck.
I will check out local hardware store/eBay for those little gems instead!
Im planning to upgrade my 13s e bike with a vesc. Is there a reliable vesc for 13s or possibly even higher voltage? If i use use a 12s vesc i need a lot of caps and a TVS diode right?
Im asking this because my Hub motor does not even get warm with my 1500w controller and i was planning on pumping some more amps though it to get better acceleration and (Maybe more speed)
No, it wonât work without the controllers being custom-designed for it.
Has anyone else drilled the motor wire holes in the wrong end of the enclosure?
Just run with it. Now itâs a front wheel drive.
Not yet, but I did just spend 2 hours today flipping my enclosure/motors b/c of a similar screwup.
Lol, Iâll just run the loop key through it and say it was intentional
Any reason youâre not considering a purpose-made ebike controller?
Just go 4wd
Will any abec adapters work for the TB DD, or does it need to be the TB adapters. I donât think @torqueboards sells just the abec adapters by themselves so Iâll have to get them elsewhere. Just wondering if the ones on say esk8supply would suffice? I only have the level adapters. Thanks.
You could use 2 ESCs and parallel the power stages and use only one of the ESCs for control, but it would take so much work to make that happen correctly, youâd be better off getting a bigger controller instead, like a VESC 75/300 or ARC200 or something
