Just watch some video where some arduino case is built then you’ll get to see every step and by that learn basics.
Because the Unity is based on VESC, it can work with any normal PWM remote receiver, which is what Trampa calls “PPM”. So any “RC remote”
Here’s a great article about remotes, you will probably find one you like.
Cool. Let us know, then !
Any suggestions on getting motor plate to stay in place. Only one of them is having this issues the screw has blue loctite and I’ve tightened it super tight and the belt tension is you average tightness with a little play in it.
Yep.
- If it moves, tighten it up with loctite.
- If it moves again, take it apart and put JB Weld (8265-S Original Steel) between the plates and all over the intersection between all pieces; retighten with loctite. Let sit for 3 days without touching.
- If it moves again, shitcan it and use a different mount and truck hanger.
Anything else will just make you crazy eventually
my motor is not detecting properly this is the results when i run the FOC Wizard
this is the result with the sensor wire attached. the motors rotated but still have glitches, and when i tried running it normally it won’t move.
this is the result with the sensor wire not attached. the motor did not spin at all.
any help will be greatly appreciated!
If it was my board, I’d just run the detection as unsensored BLDC and use it that way.
Not sure if that’s what you’d want, but that’s what I’d do. If you’re using bindings though you may need the sensors. Otherwise they are just an extra thing that can fail IMHO
when i run detection on BLDC it says detection failed :<
Click the and follow the tips. I usually have to double or triple duty cycle and sometimes increase current.
i will try that. thanks!
Twin sk3 on 218’s Not witchcraft. Get about 2mm between all things and 5mm between the motors.
And cut that hardware down right now.
Pm me.
They hexl trucks?
The Metal plate on the Motor is more of a heat thing or to “dust/rock Proof” it?
Can you explain how you did that?
What, me? The quote?
Excatly how you did it. Pressed on reply and clicked on the speach bubble on the top left.
I assume you mean that? :
