Yup, letās go to PM.
if anyone is interested, ive come up with a solution for this
https://forum.esk8.news/t/noob-question-thread-ask-your-questions-here/126/4455?u=olsyke
i went ahead and used a second pair of caliber clamps, and shortened the bolts to achieve this:
so far its holding up really good! its probably not the cheapest solution, but its what i had at hand
Would not have thought of that. Interesting. Great to know!
Yes, I wouldnāt have thought of that either. Great idea!
Once the clamps are where you want them, JB Weld Original 8265-S makes temporary things permanent
jb weld stuff is pretty hard to get around here,
what is the difference to regular epoxy ?
Any epoxy from an automotive parts supplier thatās designed for engine block repair should work also.
you seriously saved me a sledgehammer computer thank so much man. I was up looking up prebuilts almost ready to give up.
MY problem, was vesc lol
Ackmaniacās looks the same but whats the difference?
Everything connects no problems, no errors, its doesnāt randomly name your slave ( even though it never has the pop up to call a certain esc slave or master, ) it just works!
Happy to know you plowed through
As for the differences, yet again @mmaner is the man to talk to. If he isnāt too busy riding his uniā¦
Cutoff end at 32 just to have some room? Mine is set to start at 32v and end at 30v
30V is fine. There just isnāt much range between 30V and 32V anyway
We should have a thread just for cutoff settings
@mmaner has bruises on the insides of his knees and the front. The uni riding only accounts for one of those.
Time to start archiving stats
Iāll put a build thread together soonā¦ butttttt
Just rode belt drive for the first time. What a dramatic increase in ride comfort. For philly, the roads are absolutely terrible. Leaving behind the hub wheels For a full 90mm wheel made a dramatic difference. Power is great.
Current settings each for x2 4.20 flipsky vescs, 10s2p 30q and x2 TB 6355 190kv
Motor max 40
Motor min -35 (brakes are good right now at low speed. Might drop this back to -30)
Battery max 13
Bat min 6
Iāve twice experienced some dead feeling braking from near top speed. Wasnāt sure I was going to stop for an intersection. Whatās weird is that they feel near non existent the whole way down when that happened. But if I recreate it and release the brake on controller and brake again when it first happens, I get strong low speed style brakes that nearly tossed me off the front.
A 3P 30q is on the to do list.
Any advice on the brakes would be great
I am in France and I agree it is really hard to get it in Europe but the cheapest i found for us Europeans is from Amazon.co.uk
Obviously that option as well but I really like the steel colour of the JB WELD 50176 epoxy because getting that colour is only acheivable if you get epoxy for metal only in FR and again amazon UK was the only option
Beware that the steel color in JB Weld isnāt just a color, itās actual steel as I have discovered. It is magneticā¦
I wouldnāt use a ā6 minuteā or any quick-setting epoxy
Ah thanks for pointing that out, i had not seen that
Iām happy to help with Ack settings. Let me know what problem is. it may take me a minute to get back, I am currently on my roof with an AR-15 taken out one wheelers.
In case of zombie apocalypse, am I invited?
