Sn4Pz
September 18, 2019, 11:26pm
#3790
I found the charger port I would like to use, and its guaranteed delivery in 6 days… Except the only pin options are 6 and 7 Pins
Would the extra pins be a problem? Should I just look for another US vendor with 2pin?
E: went for another plug, nevermind
b264
September 19, 2019, 12:02am
#3791
If you want something like that, use GX16-3 and I even have some extras already in the US
Dareno
September 19, 2019, 5:15am
#3792
Wasn’t me maybe check with @BillGordon
I did warn you though…euc…
Wasn’t me maybe check with @mmaner
This is part of the Unity specs sheet. What does the highlighted mean? What can you use it for?
b264
September 19, 2019, 7:07am
#3795
You can use it to power a radio remote receiver or a bluetooth transceiver
Oh, that is what it means. So literally like any Vesc haha
Sometimes we really do fall for advertising
Is there such a thing as a nylon threaded insert? Basically a nylon lock nut that is an insert. I tried on google but nothing came up.
mmaner
September 19, 2019, 11:39am
#3798
I can check with @longhairedboy if you like?
Hmm I’m surprised I’ve never seen this idea implemented. I mean, we blue loctite into threaded inserts sometimes so why not?
Go make your millions, I’ll allow it.
Thank you for your appreciation my good sir. Sometimes I feel like a great artist. Misunderstood in my own times.
DEEIF
September 19, 2019, 2:31pm
#3801
Calling @mmaner @sender and others…
What would I set my battery percentage (10-20-30-40-…) if my batteries 0 percent is 3.08 a cell?
Flasher
September 19, 2019, 2:37pm
#3802
@DEEIF here you go (.112 increments)
0% 3.08
10% 3.192
20% 3.304
30% 3.416
40% 3.528
50% 3.64
60% 3.752
70% 3.864
80% 3.976
90% 4.088
100% 4.2
i’ve looked high and low for this. an M4 threaded insert under 10mm with a nylock ring towards the bottom end… yes please. Somebody needs to make this.
Myke
September 19, 2019, 2:39pm
#3805
I would just add .112 for every 10% ( 0% = 3.08 10% 3.192 20% 3.304 ect…)
@AlanZhou nobody’s banning you. At least not on purpose.
DEEIF
September 19, 2019, 2:42pm
#3809
Final q, what’s a good motor amps minimum and battery amps minimum? (12s4p 30Q)
