Got a link?
Tayto don’t have tails :frowning:
Good length
Kicktail
Nice profile
Lots of bamboo and fiberglass
10" side down the whole body!!!
Does start at $132 though
Top notch esk8 material
Powell Peralta OG Bug with tailbone
I just can’t stand fishtail decks :face_vomiting:
The wide nose under your front foot offers stability at higher speeds.
But it’s also stubby af…it’s a nickel boards chunky cousin basically
Exactly, which means you can carry it by the nose … and pop it up with the tail to grab the nose, without bending over, and carry it with one arm straight without it dragging the tail on the ground.
@b264 @wafflejock @ShutterShock i uploaded 6 pic and only two appeared. Here ya go, and here is the link to the 10s bms.Also, evolve has an 11 plugs And 11 wires if that helps.
I would imagine then that the evolve bms uses a ground wire pin. If you probe around with a multimeter you could easily find out if that is the case, checking where the voltages change or doing a voltage check between the black pin and ground. You would want to see what order the voltages increase in as well so as to not wire it in the wrong order on the new one without the ground pin
@ShutterShock thanks. Can you find me a wiring diagram that can help me understand? I will give you the readings of the volt meter asap
Did your d140 not come with a wiring diagram?
nope. only the links i put above
Hello All, One of the VESC cables got disconnected and shorted both VESCs. I don’t see any burn marks.
  1. Is there any easy way to fix them by swapping components? I’m using Torque VESCs
  2. Is there a way to prevent the other VESC to short ?
It’s a strong guess of mine that the red wires on the end line-up, and one side the black wire will not be present on the other one. The PDF has a diagram for the D140, so just check the wires with a multimeter (DO NOT ACCIDENTALLY SHORT THEM) and the most positive wire lines up on both of them. The one with only ten pins will be missing the most-negative wire.
The only thing is that the PDF does not correspond to my bms. the one i ordered doesn’t exist anymore, it got replaced with the d140. @EboardSolutions can you help me? which bms did i buy on order #1780 ?
Hi @PixelatedPolyeurthan
Yes I stopped selling them because I have now the bestech bms’s wich are much more reliable. Would recommend to use that one!
You have the d140 aswell?
No need to open your evolve pack, just solder the new connecor on the original balance wires.
I just see now the wiring diagram of the d140 is from a 7s battery, will check for the correct version!
kind regards
Frederic
Salut Frederic!
I don’t think it is the d140.
Here is a picture;
Anyone know the problem? Whenever I try to auto connect on ackmaniac’s tool on Mac it gives me this error. I tried it in the bldc tool and it won’t detect a VESC in the serial connection tab either. Just some Bluetooth devices.
did you try to start your Mac new?
I’ll try restarting it now
