Looks like it, they accept standard 200x50 tubes and tires?
Idk⌠theyâve just been sitting in a box getting moved around my house for a year.
Bought a complete mtb so mmaner could get the deck. J0KER3366 got the trucks, this was whatâs left.
I can pull then apart and check tomorrow. Already put them away. Getting ready to crash.
Change of trade for the ABECs?
8x2 and 6x2 rims arenât compatable right?
I wouldnât think so.
If you want them send me a pm. Weâll work it out.
Has anyone tried this vesc?
Pretty good? Thinking of getting it for my next build. Iâm staying away from enertion at the moment.
So⌠why isnât there any tubeless pneumatic wheels out there? Rimtape and a compressor⌠wouldnât that work??
I actually havenât tried it yet. Still building.
Its new. Iâd probably sell it at a good price if youâre interested.
Out of curiosity, what is the weight of the EVO deck?
I want to add TVS diode to my build (im using Flipsky Vesc 4.12 and 10s4p lipo + DieBieMS) where exactly should i put it and what are the specs of the diode ( i mean V, A , W)
Its a silly question, but is the rush of current when plugging in my charger similarly detrimental to the rush of current when powering my antispark (luna 100a switch) on? I know that more advance antisparks have a work around for this, but do BMSs? Is there anything I can do to help sustain the health of my BMS?
I figure they are built to handle it, butâŚ
Plug your charger into the board first then into the wall. The charger will help attenuate the surge.
Gotcha. I figured it worked in a way similar, I just didnât know if there was anything more I can do to help it
Does range per volt drop as voltage drops? Like if Iâm getting 3 from 40 to 39 volts, will I still get 3 miles from 33 to 32 volts?
I would think so (that range per volt drops as voltage drops), because at a lower voltage you need more amp hours for the same amount of energy (watt hours) which determines range, and the voltage drop curve of batteries being drained at a sustained power level is not linear. (Itâs quite linear if discharged at a constant current, which leads me to believe it wouldnât for constant power)
No.
Also, high-quality chargers donât even have that issue, they ramp the voltage very slowly.
Cheaper chargers do that though but itâs not an issue.
Average deck is around 4-5 lbs
Any USA resident who services MCU repair?
