This is the plan i’ve been baking for if i ever need to do it
I’m working on doing this for reacher motors + jump drives, but with a lathe.
do the pinions have enough surface area to simply trust loctite 638 to do its job?
With a high power board I’m not gonna try my luck.
No, just my opinion. Just reengaging here for the first time in a bit, so take my opinion with a grain of salt.
Hmm that’s unfortunate. If only I had a buddy who was a master machinist
Just kidding, great to see you back around here Phil!
For whatever it’s worth, these look like mod 1.5 straight cuts.
Mod 1.5 is was SRB uses, and it has a very raw (harsh) feeling. My mod 1.5 open gears scream like banshee on hill climbs, to the point that it is pretty unpleasant even with a full face on.
Mod 1 straight cuts are very smooth in comparison. They still make more noise vs helicals, but they don’t have the harsh feeling that mod 1.5 has. I can completely understand why the apex team wasn’t thrilled with mod 1.5 staight cuts.
I just got my hands on a 4wd set of jump drives, so I’m stoked to try out my first set of helicals and see if y’all can convert me to team helical for good
Yes, please @ApexBoards make a straight cut mod1 set of gears for us to buy!
I have a 4wd build on mod1 straight cuts and the sound is pretty pleasant in my opinion
Your circlip stuff is cool but I like even points of failure
+1, would be absolutely down to pick up some straight cuts around the higher ratio. I would like to use motors that dont have the circlip groove but I dont trust retaining compound.
I use Loctite 648 only without any key with 80100 motors and got no issue. Yet they have 12 mm axles what helps a lot.
Loctite 648 works good with 8 mm axles too at the condition axle is long enough and fitment with sprocket is good without too much play.
even w/ straight cuts? i thought lateral force was the enemy
A 12mm shaft gives you so much more binding area than 8, it’s an unfair comparison
Nah it works fine with straights.
It does work with 8 mm too. I’ve 5 e-mtbs builds with 8 mm motor axles and only Loctite 648 to attach the sprockets.
that sounds fine, sprockets and helical gears arent comparable. I’ve had pullies stick with just retaining compound too. I have not had helical gears stay successfully for more than like 1000km
Oh yeah axial thrust in helical gears adds a problem I didn’t thought about that. 1000 km is not that bad anyway.
It’s pretty bad if it strands me in the woods and/or destroys my geardrive casing.
My M1 helicals are going strong on 8 mm motor shaft with only loctite 2 yrs , Hunderds of miles 600- 700 and out lasted a focbox, dv6 and stormcore and 2 motors but on a thane build.
Two loose m1-at helicals and loose moon drive metal helicals over 2000 miles for me. Doubt it’s user error as boardnamics assembled my second m1 helical.
