I’ve got a couple motors I’d like to find what max current is possible before the stator saturates so as to set amp limits and build battery series connections.
It is in pieces, still need to build it
With so many cheap escs using firmware allowing huge amps be good know what’s worth putting in the motor. If u get around to building it and want to try some motors I’d bring them
The guy behind the momentum hollow wheels has some custom test jigs for his wheels, maybe he could retrofit one of them into a motor dyno?
We’re in the process of building one here at Hoyt in Portland OR
All I can do is get them as hot as they will ever get. If that interest you I can try to help. All I really do is ride steep hills far too fast for comm sense.
I’m also a curmudgeon so I have lots of time for to skate .
I can confirm Artem’s motors can take 116c for a very long time. Good luck,thanks for moving the thec forward.
I’ll get on it!
