There are also performacne washers.
Plus one on this. M4 barrel nuts w/rubber oring under fender washer, no loctite for undermount enclosure, doesnāt loosen a bit.
Might have to go with these
fender washers, aka cone or countersink washers (depending on bolt they are for) as decorative in our application. You do not want to skip the steel flat washer underneath it. The countersink washers arenāt so bad because they arenāt paper thin, but the cone washers will absolutely let the bolt pop right through if thereās any real load on them.
My stuffs held on by 6 standard truck mounting bolts, with a couple washers under the nuts. Its far from ideal but it hasnt failed me since i deck swapped in march. Hell, 2 of them have hard bushings as spacers, to make up for concave, and i just gasketed around the entire thing. Its some frankenstein shit. Dont be like me. Ive got proper hardware for the build im workin on now.
No, fender washers are flat washers with a large OD relative to the hole size.
Those aluminum countersunk washers are purely cosmetic. These are designed to spread the clamping load over a larger area.
Alright so I did get the screws but Iām confused if I need more things to add along with it. Kinda forgot what was needed or how to assemble it all together in order
Personally, I did mine like this:
Bolt head - metal washer -
Rubber washer - deck/enclosure - rubber washer - metal washer - other bolt part.
The metal washers helped spread the load on the deck and enclosure since I like offroading a lot.
The rubber washers compressed and help keep water out⦠since I like offroading a lot.
Use a drill bit the same diameter as the post on the female bolt or a hair less. Hammer it in to the deck tight if you need to. Some people epoxy them in, some donāt and rely on them being screwed together. Good point to bring up that you should use blue loctite so the bolts donāt come undone after many miles.
You know what size to get for each of those? Going to Home Depot later today to get some
The thicker side has an 8mm or 5/16" diameter.
The thinner side has a 6mm or 15/64" diameter but they never have that size in imperial so 1/4" will likely be the closest you can get.
Bring one of the sex bolts with you to the store to be safe. If you have an Ace hardware near you, I recommend it over lowes and home depot.
I used the search button. This is the most relevant thread Iāve found on it.
