Afraid not, currently stuck on an island on the outskirts of Europe.
@Pecos Something else to consider that i’ve just thought of is, in the vid I posted above, when i press the power switch, it is only in that instant of firmly pressing it that the ohm reading hits zero with an immediate return to the previous
52 odd ohm reading (unless i hold it in for a couple of seconds, which kibd of locks it into that reading)
Does that make sense ? Maybe i’m covering old ground here and that’s what you initially meant by momentary.
I do have here right now a Flipsky smart anti- spark 200A with mini switch but was told there’s an issue with these requiring capacitors ? ? ?
Ideally, I wanna keep this internally as stock as possible until the battery needs replacing but desperately need a board working now.
What should my next move be ?
Check all Vesc settings as is, thru wired cable (yep,it’s that old) then replace sentinel with Flipsky if all variations of switch error have been tackled ?
Gawd, electronics, the learning curve is steep !
I’ve got 2 hours to get this working . . .
