I push around 100-120 max. How would you push 160?
I thought you meant 160. Unity “Can” handle Max 80A+80A. Is it okej att 120? It doesn’t get very hot?
Wow those are beautiful. Nice work.
It’s fine don’t even worry about it
Battery Max setting is 120A
What stops you from running 160 like Enertion says it can?
Anybody have Metr data of max settings yet? Would be great to see temp data and everything.
Ooh sweet! those green cables look as if a liquid coolant is being pumped through those “engines”.
Haha yeah It kinda does. I like it I think it’s a nice touch.
Update time!!
The trucks and wheels are on.
Really shitty weather ice everywhere it’s like glass is shining. No testing yet. But shit whey wobbly as fock.
Maybe it’s the shitty heavy 6x2 wheels I have on.
Unitys toothpicks wires off and replace with 12Awg and 5.5mm bullets
Now I have the battery left to do. But no rush for Mee. Plan is to get it done before end of April.
Still 12s4p 40T is my plan if no new super cell hits the market soon.
The P42A packs 5% more range and 29% more power for the form factor…not necessarily a super cell but still better
Catch is its definitely more costly
Absolutely not. Molicel inflates their discharge numbers. They are only slightly better than 40T.
I think he meens in a full pack 12s4p and not per cell…
From my research the Samsung 30T can push more amps before it gets hot.
If both packs are 12s4p, comparing individual cells is the same as comparing packs…
My point is, they are both ~30A cells in the real world.
30T will do more, but the capacity trade off is too much for most builds IMO.
140mm center to center to clear the deck so I can have the motors far from the ground.
It will sitt like this tested with a 3d printed dummy.
you cut that with hand tools?!
Certainly looks that way
No not with hand tools. [quote=“Chaki, post:1, topic:14199”]
I have backups just in case it turns bad.
[/quote]
This was the back upp. Just need to polish them or paint.
Could be worse. It could be made by u.
U still got ur hummie build? Still no buttons on it or have u come upp with a soulotion for the button placemats?
