There is no dedicated thread for these washers so thought I would make one. Please use this to post links, pics and ask any questions that you might have.
I was wondering if anyone has the dimension for these washers
Uh dimensions I have no idea. What do you need the dimension for ?
For making sure it is not going to rub against the enclosure walls.
50PCS M5 Cone Washer Aluminum Alloy Cone Cup Head Screw Gasket Conical Fender Washer (Blue) https://www.amazon.com/dp/B07F351GGC/ref=cm_sw_r_cp_api_i_myOaFbSBWPM86
These ones are better
I actually have those and, sad to say, they are actually worse than the countersunk ones. Because of the sharp corner at the bottom, it breaks off.
I hate ^ the ones in that photo. I’ve tightened screws down through the bottom layer at least once on every board that has those.
What breaks off? Use nylon washers underneath them…
Oh your using them for truck top mounts? I’ve only used them for enclosure mounting
yeah, enclosure might be a more forgiving application for the counterbore ones.
Enclosure isn’t I’ve even used them with metal spacers underneath and still ripped through the bottom, they just all around suck… Even though I have at least 150 laying around
Yeah i always just place a nylon washer underneath for enclosure mounting that way it doesn’t dig into the enclosure
Boy how tf you rip through em
I always use a little rubber washer under these, especially for an enclosure. Helps keep them from backing your bolts out too.
E-Skating for more then 10 miles… Shots be fired
Haha ya know what ima test this rn . Ima tighten it down as hard as possible
It’s tightening and vibrations… then retightening and removing enclosure for repairs…
Don’t tighten them down so hard. There’s no need for massive torque. Put a drop of blue thread lock in the bolt, tighten the bolt down until is finger tight, add 5 lbs, done.
Turn until you can’t turn anymore!!!
