An Experiment in "Articulated" Esk8 Trucks
I came across a thread that had some of Head Turner Customs’ coilover shock suspension trucks (see Trophy Truck Longboard Suspension System - YouTube and the similar red wheel counterpart)
I wanted to mimic this design on an ESK8, initially selecting 6" AT tires/wheels and a caliber profile rear split truck/axle for motor mounts. However, I decided on keeping it simple stupid for my initial design.
The wheels can be mounted facing outwards (as shown) or facing inwards. Hardware is standard 5/16. Multiple holes in the idler plates were added so that the wheel spacing can be adjusted.
Once I gather feedback and get a feel for this design using my existing urethane/street setup, I’ll work at creating a larger configuration with AT wheels/tires and coilover shocks.
wait until some crazy crackhead use the other holes to mount wheel inwards at the same time.
I could’ve sworn that i saw this already. Not the spring version but a regular one like yours.
On Reddit someone had AT rear drive wheels and this with urethane in the front
Yes, this single idler bar/tandem wheel setup is on amazon and other sites:
https://www.google.com/search?q=tandem+skateboard+trucks&tbm=isch
Testing it myself (with a longer center-center distance) to get a feel for what it’s like.
How is the dangerously-obsessed-with unusual-trucks @Fosterqc not in this discussion?
That might be the one!
Do y’all think an 8wd board would be possible with that setup?
8 wheel drive?
Yes, with a set of what is pictured on front and back.
Lots of things are “possible”.
Is it good?
probably through my old board setup
just letting you know, having just 2 plates and some bolts and washers will wear the axles, bend them, and will cause uneven wear on the wheels
i’ve bent at least 3 hangers in the span of a year while running tandem axles
if the title or this disc was accurate to what is being shown I would be.
“multiple wheels per axle” would be a good general thread this could be.
41veon7amBL.AC
look here is a random pic I have saved idk why
10char
Hardware (Grade 8 Steel) and SCS plates arrived:
it’s not an immediate bend, it bends over time
(120 pound)
