Hey guys, I know this is not an ebike forum, but I would like to do an ebike with Esk8 parts.
As controller I would like to use a FSESC 6.6 in its full alloy encasing.
Motor:
Option 1: one up to three 6374 190KV or 6484 160KV, with gearing ratio 10:1 via chains to mid drive
Option 2: Luna Cyclone 3000 mid drive
Option 3 MXUS 3000W V3 H45 3T direct drive hub
It is going to be the second option. Just keeping pedals as a backup.
For the first option:
You could use a sensor that measures pedaling frequency (and gear position) and adjusts the throttle based on that. But that makes more sense with motors <1500W
If you have a gearing ratio of 1:10, the motor will rotate 10x faster than the wheel.
If the gearing is such that the same motor that is used on an esk8 has the same top speed on a bike as on a skateboard, it is effectively the same to the controller.
You have problems if you don’t reduce the gearing, as a bike wheel rotates slower than a thane wheel.
Didnt use esk8 parts, but did modify almost everything. Fit the lions into the triangle. Very custom. Also light considering those engineered as elec, are a slight bit heavier.
It is an urban assault vehicle, with schwalbe marathon pluses. Carbon rims. Carbon everything but the alum frame. Top of line susp. It turned out too nice to lock anywhere. So I walk it in anywhere I go, and leave if I cant look after it.
