than copper when at the same weight.
Was reading a lot of car makers are moving to aluminum mainly for reduced cost
https://www.anixter.com/en_gb.html
If u have the room save some weight.
No, that’s a terrible idea. Aluminum is far more brittle.
It’s also less conductive, people use copper clad aluminum in wires because the higher frequencies only really use the surface of the wire. When delivering power more of the wire is used.
Is aluminium even possible to solder?
And I don’t think the weight of wire is a priority for us
Aluminium is pretty hard to solder to. I remember looking into it ages ago and from memory you need special super aggressive flux.
Given that the wire size would likely be pretty big for the currents we handle, you’d likely need to look into crimped connections rather than solder anyway
Came here to say this: crimp aluminum don’t solder.
Aluminum is more conductive by weight but not volume and why it’s used for aerial cables. It is significantly more brittle if that’s the right word - any nick or scratch in the conductor will cause it to break at that point so special stripping toools are needed to prevent any damage to the exposed conductor. It has a different coefficient of thermal expansion as a pure metal also so you have to use modern electrical specific alloys and connectors to prevent the joints from failing. Also it can’t be used in smaller sizes (6awg iirc) because the fire risk in ac system for building wires made of alu9cu rated alloys wasn’t up to the challenge.
If you have a lot of wires total where the weight of the conductors is starting to become a serious percentage of the total vehicle weight i can see it becoming worth the effort to reduce the vehicle weight. It may be a fun experiment but isn’t really applicable to regular pevs or eskate in general - more of a solution to a problem that doesn’t apply once the total vehicle weight is under 2000lbs or where volume of the conductor is less important than the weight.
Remember that alu alloys need to go up about 2 sizes for an equivalent conductivity and will be about half the weight. So if your total wireing harness is 2 lbs you would only get 1lbs of weight saving but all conductors will need to double their diameter - ie a 12awg will need to be replaced with a 8awg
How does aluminum fare versus copper in malleability, if it’s exposed to repeated vibration?
Aluminum is less malleable and more subject to fatigue cracking
Seems like it may not be worth the extra grams of weight savings if it could affect safety, in my opinion.
not for everyone. U have to be super hardcore gramcounter/ penny pincher
